‎07-20-2021 04:14 AM
Hi you
Can I use a Adaptor 54V 0.65mA POE power supply standard 802.3AT?
AP7562 I use the highest power with 6 antennas
Solved! Go to Solution.
‎07-20-2021 01:37 PM
Hello Tuan,
As long as the PoE injector adheres to the 802.3at standard, you should be OK.
Checked the lab PoE injector with following specs:
Output: 55V, 0.6A
I hope this helps,
‎07-20-2021 01:46 PM
A little more clarity on this:
With .3af power, the 5GHz radio (radio-2) will downgrade from 3x3:3 to 2x2:2 (3 spatial streams to 2 spatial streams). With only .3af power, the second Ethernet port (ge2) is shut down.
With 802.3at power, full functionality is provided.
Hello Tuan,
Output: 55V, 0.6A
I hope this helps,
