Wing v5.8.5 + v5.8.4 - AP7522I adoption failure
‎07-23-2017 11:57 PM
I'm trying to set up 3x AP7522I's with one of them as a VC controlling the rest. Network is flat and there is an external DNS and Router to outside the network. IP Addressing is a private network with a /24 range. I'm using a small PoE switch (no VLANS, nothing special) to set this up, and have used this same switch with previous setups for initial config.
With previous versions of WiNG (Zebra/Motorola days, as late as v5.8.2) the initial web interface setup process guided you through setting up a basic config, adopting the AP's, etc. I found the new "Startup Assist" button, but it's no where near as detailed as the old process was.
That said, the main issue is that I can't seem to get the VC and AP's to communicate properly. It seems like the AP's aren't being properly adopted by the VC.
VC AP is running v5.8.5. and the AP's are running v5.8.4 (firmware as they came in the box, the VC was just the unit I connected to first). I suspect that they all need to be running the same version (it's usually what I do), and this is actually a result of the version differences between AP's.
Notes:
If so, where do I go from here to get these AP's all on the same version of firmware? As mentioned, I haven't played with this stuff since it was all Zebra (though I did deal with Motorola and even Symbol well before that), and everything changing around support has definitely thrown me a curve ball here.
While I could probably step the units back to v5.8.2 firmware, I would prefer to go forward, rather than backwards.
If there's some other way to force the AP's to connect to the VC (eg: CLI thru serial/SSH), or debug commands I can run to try and pin down the issue, I'm all ears.
PS: I have about 16 similar configs to this on older firmware.
Notes:
- The VC is also set up to provide DHCP services.
- On the VC I can see the AP's in the Access Points list and can edit them. However the AP's get DHCP addresses and no matter what I do, I can't give them fixed addresses (which are outside the DHCP range), despite each AP in the web interface on the VC showing details I've set. They also don't pick up any of the configured WLAN(s).
- Looking at the non-VC AP's directly shows them to have default configs.
10 REPLIES 10
‎07-24-2017 11:01 AM
Bingo. Exactly what I knew must be buried in the cli that would tell me what is going on. Been a while since I've played with these and been even longer since I did training on setup/WiNG 5 back through Motorola. Many thanks Robert!
‎07-24-2017 12:09 AM
In my experience the firmware will be the issue. For config to be properly passed from controller to AP the firmware needs to match. What you need to do is update the firmware on the VC AP - even if you're reapplying the same firmware version.
Doing this updates both the boot firmware, and stores the firmware file in flash for deployment to adopted APs. Without doing this the APs on other firmware will never adopt.
In the old days, uploading deployment firmware was a separate step, now it's built into the VC AP firmware update process.
I contacted GTAC and they provided me with firmware. Thanks!
This link on the new portal is preferred: https://extremeportal.force.com/ExtrDownloadDetail?id=a4134000000YiaOAAS
