‎06-08-2021 07:43 AM
I’am not able to select a reference firmware for the X435 switch.
For X440-G2, X450-G2 it is possible to do that
Solved! Go to Solution.
‎06-08-2021 01:34 PM
Miguel-Angel,
I thought I uploaded the correct firmware .
Now I can select the x435.
Thanks
Miguel-Angel,
Thanks
‎06-08-2021 12:19 PM
Johan,
If I remember well, the X435 is using another binary file (arm CPU).
Did you uploaded the specific firmware for this family?
Mig
