ip forward-protocol from Enterasys syntax to Extreme
  • Question
  • Updated 1 year ago
  • Answered
Hello Guy,
how to translate these commands from Enterasys to Extreme 460?
i haven't found the right command  and no port on this so far.
 ip forward-protocol udp 2009
 ip forward-protocol udp 3001
thanks in advance
Photo of Gradelain Ngouni
Gradelain Ngouni
  • 480 Points 250 badge 2x thumb
Posted 1 year ago
Gradelain Ngouni
my goal is to allow some ports which are not allowed by Default...
following is already implemented:
configure bootprelay add <Address-of-the-Server> vr VR-Default
enable bootprelay ipv4 vlan <the corresponding vlan>
what is missing is to allow the relay over  UDP port  2009 and 3001.
Any help is appreciated.
Thnaks
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
UDP profiles should be used for that, assuming it is udp broadcasts to these ports.
https://gtacknowledge.extremenetworks.com/articles/Solution/UDP-broadcast-packets-are-dropped-by-EXO...
Gradelain Ngouni
thanks a lot. issue solved. regards
Gradelain Ngouni
