open device terminal in XMS (web version Netsight) cann't connect to switch with SSH
  • Question
  • Updated 7 months ago
  • Answered
How can I change the port number op the open device terminal ?
Now I got  an error: Failed to connect
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,712 Points 3k badge 2x thumb
Posted 7 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,954 Points 20k badge 2x thumb
I don't think that is possible in the GUI, the default for telnet(23) & ssh(22) is used.
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,610 Points 1k badge 2x thumb
Johan,
the open device terminal defined in the CLI Credentials.
You need to go via Administration>Profiles>
there you see the SNMP Profiles and on the right side the CLI Credentials you use. On the CLI Credentials TAB you can create SSH/Telnet profiles, this now combine with the SNMP profile allow you the right click action.
regards
Bastian
Johan Hendrikx
Bastian,
I have created the CLI credentials. When I use the JAVA console, SSH works fine
