How to create "top x temperature" report for the netsight dashboard?
Viewing the Netsight Network dashboard there is amongst others a "device CPU window". How to create such a "window" showing the top 5 XOS switches with the highest temperature?
Hello, after reboot netsight server I got the failure: WFLYCTL0184: New missing/unsatisfied dependencies: service jboss.deployment.unit."Monitor.war".component.DerbyDatabase.START (missing) dependents: [service jboss.deployment.unit."Monitor.wa...
I have installed a new Extreme Management server on Ubuntu. I am not able to login for the first time but get a message immediately that user is not authorized. I am using the same user name and pw that was used to set up the system and login to th...
Do you have to configure each port on a E4G-200? We currently have 1 T1 used (port 1) we moved it over to port 2 to check it out, but it would not work. Is there something that needs to be configured to do this?
Hi i want to ask how to upgrade firmware on Extreme Management Center, from Firmware 7.1.2.12 to 7.1.3.25 ? which firmware should i download?i have download nac_appliance_64bit_sw_upgrade_to_7.1.3.25.bin to my laptop is it the correct file? and ho...
| User | Count |
| 106 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
