Enterasys NetSight Suite 5.0.0.252 Windows server compatibility
We are planning to upgrade to Windows Server 2016. Will this version still work? If not, what version will?
What will be with the feature of WIFI management in the Management Console with BASE license after deactivation of JAVA console in V9? The description in the DS is: NMS-BASE-XX Includes basic wired/wireless management features as well as inventory ...
Hi, I have a customer who would like to view the unused ports report from Netsight for all his EXOS switches. I had contacted GTAC and I was asked to add the Port_Status_Time_with_alias.tpl file and create a flexview. I have done this and I am able t...
I want to be able to make modifications to the after-login banner on my 4,000 switches. I would like to use a TCL script from within Netsight to do it. I have the entire script working except that I found that the "configure banner" command is uniqu...
Is there a way to import a list of MAC addresses into the NAC? Example: A list of printer MAC addresses that need to be authenticated and placed in a specific VLAN.
| User | Count |
| 102 | |
| 101 | |
| 42 | |
| 19 | |
| 17 |
