ports usage capacity report
How do I create and send via email for the used ports capacity report from Extreme Management Centre.
I need to configure my switches and netsight to give an alarm every time a port state change. It'd be amazing if I can configure different alarms with different names for different ports! for example: -port 1 - alarm1 -port 2 - alarm 2 and so... No...
Hello, everybody! I have Netsight 6.3.182 and a lot of Extreme switches with LLDP enabled. I've added them all to the Netsight over SNMP and made a topology map in Oneview. All the links between Summits were drawn and everything is OK. Two days ago...
hi I want to configure snmpv3 in NetSight to receive the traps in a monitor system of solar winds?? Regards.
Hello, everybody, now I can find syslog messages only in Legacy Java "Console" application. Could it be found in Oneview? Thanks
| User | Count |
| 101 | |
| 100 | |
| 42 | |
| 19 | |
| 17 |
