Open backup configurations stored by Netsight
I was interested to know if there is a way to open the backup EXOS Summit configuration files saved by Netsight to view the configuration.
Hi guys i have enable nac load balancing. I am unsure how to check itis working. what i have done is added the address of the NAC appliances to the external load balancer config of the nac group . according to the docs, i am suppose to get a VIP. ...
Hi, I configured a notification E-Mail in NAC Manager if a unknown user connect to a Access Point. After Upgrade the NMS and NAC to 6.3.0.186 I get 3 or more E-Mails to the same issue. Anyone a idea?
Hi, after installation of 8.0.2 I cant find Access List Manager and Editor functionality on the Legacy Java Client. Have they been removed?
Hi, we are using virtual Management Center 7.1.2 connected to an internal network. For Update Checks we are using a webproxy which is configured in EMCs Settings. Release Notes says that you need internet access during upgrade. I tried to update our ...
| User | Count |
| 101 | |
| 100 | |
| 42 | |
| 19 | |
| 17 |
