i required OS 7.4.4.9 MIB, Please
Hi I need the MIB File of “extremeware Version 7.4.4.9 [non-ssh] [base]” This version is currently in use on the BD6808 and Summit48. It is not visible in the software & download section of the portal. Please ...
I have couple situations when i need to configure Captive Portal not only for unregistered profile. For example for substitute of two phase authentication, when already authenticated user need additional authentication/authorisation to proof his righ...
It would be nice to check more than one end-system or user group when validating access control rules. Also it would be great to put end-system/user into temporary group when we authenticate host and user in sequence. In many cases there is need to...
We would like to use a SSA-T1068-0652A to gain NetFlow and MirrorN data. Do we need the S-EOS-S150 license to tunnel the mirrored data to a PurView appliance? Kind regards Christoph
Virtual Wireless Controller V2110 Large running v10.11.03.0004 has a kernel failure two days in a row. Any thoughts? There are two controllers running in HA(sync) mode with approx. 725 3825i APs spilt between them. Have not seen any other alarms or e...
| User | Count |
| 94 | |
| 93 | |
| 41 | |
| 19 | |
| 17 |
