NetSight Console: Text Size
Software Version: NetSight Console 6.1.0.171 Can the text size on the console be changed? If so, how?
Is anyone aware of a retention setting for location data in Netsight (in regards to wireless clients)? I find that when I am tracking a client, I can usually only roll back the past 15 minutes or so. Certainly no more than an hour. Is this data comi...
Wow just received a notice on my Extreme 360 App... "ExtremeAnalytics will be live in the NFL Command Center. "Brought to you live from Command Center in NYC and Houston, TX for Super Bowl 51!!! That would be great to see the live analytics as the g...
We have a mix of X460 G2 and X440 switches that each have their own local time set on each device that is not the same. Is it possible to use NetSight / Extreme Management to sync the time of all switches to an NTP server?
Netsight Installation
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
