Changing serial # on AP configuration
Is it possible to change just the serial number for WS-AP3865E series AP throught the NAC GUI and keep the existing configuration?
Hi Community Within Oneview custom reporting you can save the results as a Excel spreadsheet. This same option is not available for the Application (Purview) data. Can this data be saved as a excel spreadsheet? If not is their a way to gain access ...
Hi all I have some questions regarding the reporting of "Identify and Access" and Purview reports that we see Identify and Access If I look at the "System" tab in oneview it reports in the top left corner "Overview". The "Seen last 24 Hours" is al...
Netsight 6.2 - Console - Alarms Manager In which file are the alarms saved? Is it possible to edit this file?
I've added the right OID in the trapd file for Auth. failure on a HP switch. After receiving the trap there is no alarm ? Version Netsight 6.2.0.221 What's going wrong ?
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
