backup netsight automatic
Its possible automatize netsight database backup and export database daily ?
Hello: Just a final reminder that the Extreme Upstate Users' Group will be hosting a Netsight conference on June 11th at Nazareth College in Rochester NY on June 11th. We hope to see you in person but if you cannot make the session will be broadcas...
I was reading the oneview guide and trying to import maps to one view for wireless converage. So according to the guide when I try to set the scal it should have a field for "Units". When I got to do it Units isnt there. Anyone else having this...
NetSight client-settings at the end-users are lost after upgrading from NS5.0 to 5.1. Settings like added columns, change sorting, local scripts are lost. With the 5.0 upgrade this should be fixed and the most settings are obtained with the 4.x to 5....
Hello, can anybody give me the Keyboard shortcut, to enable Administration tab in NetSight. I forgot it. Thanks Nico
| User | Count |
| 102 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
