Resolved! Map creation through NBI
Hi,Is it possible to create map through the NBI ?Regards,Jave
I'm working on some queries to the NBI interface and having trouble filtering the endSystems returns. Here's my query:query { accessControl { endSystems(maxResults: 25) { endSystems { firstSeenTime lastSeenTime ipA...
Hi community, I created a workflow that is working on 1 or more Juniper EX switches or MX routers for retriving the chassis alarms that are active in the moment I manually launch it in the everyday functioning.I need to trigger this workflow every ti...
FN-2023-486-Performing a configuration enforce with ExtremeCloud IQ – Site Engine 23.4.10 or 23.4.11 against a VOSS/Fabric Engine node with auto-sense support could trigger ISIS to be disabled on the switchSummary:When performing a configuration enfo...
Hello, is it possible to create a service ( policy )that simultaneously blocks access to an ip on a specific portwhile allowing access to the same ip on other ports?For example, can I create a service to my server 192.168.0.1:3389 and permit access t...
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
