‎01-29-2019 03:09 PM
We have an X440G2 running 22.4.1.4 22.4.1.4-patch1-2 that correctly shows the configured port display string in the "Switch Port" column in XMC. We have another X440G2 running the same version of XOS but the display strings for each port are not showing up in XMC for that switch. We thought we had them configured the same, but clearly something is missing. What setting controls that information being polled from the switch?
Solved! Go to Solution.
1 ACCEPTED SOLUTION
‎07-03-2019 08:07 PM
Now that we are running 22.5.1.7-patch1-7 and MAC authentication, the "Switch Port" column is correctly showing what is configured via "display-string" so it seems like it was just an issue when using identity management.
6 REPLIES 6
‎01-31-2019 09:01 PM
That was a suggestion that I received (using description string), but I don't understand why display-string works on the one switch using the same settings. We would rather only have to configure one option on each port and be able to query the results in XMC and in Cacti.
Regarding the version, we are trying to stick to the "most stable release" as per https://www.extremenetworks.com/support/compatibility-matrices/sw-release-extremexos-eos/?_ga=2.160210622.28786639.1548692841-1377444939.1542305913
i recommend use 22.6 patch1-1 - netlogin runs much better than with 22.4 ...
‎01-31-2019 08:59 PM
set display string also as description string on the ports and this will works reliable !
