how to restart a port of B5 series switch (power down and restart)
Visconti
New Contributor III
I need to reset (remove voltage and restart) one particular port whitch is connected a network clock.
This clock is in crash and I cannot go on site to disconnect the cable
5 REPLIES 5
Baris_Karabacak
New Contributor II
As Anton said you remove the voltage with ...inlinpower.
But set port disable is also an Option to disable the network traffic.
Therefore: set port disable ge.x.y
set port inlinpower ge.x.y admin off
I prefer to wait at least one Minute and then restart the power and traffic:
set port inlinpower ge.x.y admin auto
set port enable ge.x.y
Why this?
i had an issue with a Controller. I tried several things. Then forgot to enable the port because of interruption. Then if i concentrated on the issue again, enabling the port, the Controller woke up.
May be you have a similar Situation.
Greetings from Nuremberg.
Martineau__John
If the clock has a static IP, the unstable state may have returned the device to factory default or is in a dead state. IF IP is dynamic, please verify DHCP server sees request and has an entry in its database.
Ronald_Dvorak
Honored Contributor
If the clock get's the IP via DHCP check whether there is a renew of the lease.
If the clock has a static IP it could be that the device lost the config.
Visconti
New Contributor III
Ok I followed your advice and infact now I see the mac of the clock connected to this port but when I ping the ip I do not receive any feedback
