is there an API for XIQ-SE to read Meraki dashboard
JohanHendrikx
Contributor II
I want to read from the Meraki dashboard the switches and AP's to import into XIQ-SE.
Is there such an API to do so?
Johan Hendrik System Architect Audax
1 ACCEPTED SOLUTION
Markus_Nikulski
XIQ-SE owns a North Bound Interface (NBI) which will allow third-party vendors to read and configure several things including what you looking for.
Using the Northbound Interface to Integrate with Third-Party Software (extremenetworks.com)
2 REPLIES 2
Ryan_Yacobucci
Hello,
The workflows also has an "HTTP" activity where you can utilize web connections to 3rd party devices to gather information.
In theory, you could perform a web activity to gather information, then use the NBI to add devices into XIQ-SE.
Thanks
-Ryan
Markus_Nikulski
