Virtual Wireless Controller V2110 Large running v10.11.03.0004 has a kernel failure two days in a row. Any thoughts?
Dean_Ferraro
New Contributor III
Virtual Wireless Controller V2110 Large running v10.11.03.0004 has a kernel failure two days in a row. Any thoughts? There are two controllers running in HA(sync) mode with approx. 725 3825i APs spilt between them. Have not seen any other alarms or events associated with this except when checking on status of virtual server cli. All APs are currently running on a single controller and there does appear to have a secondary tunnel back to primary controller. Has anyone else experienced similar issues and any suggestions on how to determine root cause and solution will be greatly appreciated.
12 REPLIES 12
Ronald_Dvorak
Honored Contributor
Have you set the SCSI controller on the VM to paravirtual as mentioned in the release notes ?
Scott_Whall
Hi Dean - you can get the Tech Support log files for each V2110 and open a GTAC case, or you can try upgrading to 10.11.06, which is on the Support Download site.
