Connecting 2x Extreme switches on different floors.
ExtremeNewbie
New Contributor II
Hello Community,
I have 2 x 5520 switches based over 2 floors.  I believe I cannot stack these due to the distances involved.  However, I do have a fibre connection between the 2 floors.
What is the correct way of connecting these 2x 5520 switches?  Ideally I would like to stack these but this is not possible using the stacking ports.
Do I create a new port sharing group e.g. using ports 59 and 60 on each switch and use SFP+ modules on each port on both sides adding the VLANs needed or is there another way to do this?
Much appreciated.
1 ACCEPTED SOLUTION
Ah, didn't know that you have VIMs 🙂
You can use both ways. In order to use QSFP Ports you have to disable stacking-support. If you use the VIMs to connect the switches you have the option in the future to add a new switch on the floors and stack it with the existing switch on the floor.
6 REPLIES 6
Hi @Stefan_K_
Thanks for the quick reply.  I am suggesting using the VIM ports for the connection as we have VIM modules we can use.  This is why I have suggested using ports 59 and 60.  Are you suggesting using the QSFP ports instead for this?
Kind Regards,
