X440 G2 management login problem
Nico_Willamowsk
New Contributor III
Hello,
i have the following Problem. We authenticate to our Switches via Management Login and LDAP. Since the Firmware Upgrade to Version 22.1.1.5 the Management Login doesn“t work, but only with X440 G2 Switches. With X460 G2 it works. Does somebody have an idea?
8 REPLIES 8
Bastian_Sprotte
Nico,
please enforce the Radius config via the NAC manager again.
let us know if that fix the issue.
Bastian
M_Nees
Contributor III
This confirm my assumption (unfortunately). Extreme QA as it best.
Nico_Willamowsk
New Contributor III
No, i was not copying a config fron another switrch. You can see the follow. I was upgrade to Version 22.1.1.5. Thats what i mean with "after upgrade". Then i downgrade to Version 21.1.2.14. That“s what "before upgrade" means. I also saw that the config is the same. But the strange Thing is, after downgrade the mgmt Login works fine.
Baskar
Hi Nico,
I would like to know, did you copying an existing AAA configuration from a switch and configured in this switch ? if so it might be the reason,
Because the hash algorithm used to store account passwords was changed from MD5 to SHA-256 in newer EXOS version.
