ā08-13-2024 07:41 AM
Hello,
If a site survey is carried out prior to installation of Extreme APs, should the power be set to match the radio used for the survey? So, if WiFi0 was used to check 2.4GHz band and had power level 7 dbM should the Extreme APs be configured to use the same power level? The survey identified the quantity of APs to install in each location (a warehouse). Or can they be left as Auto power?
Also, how do you create heat maps for a warehouse where the APs are installed at different heights? There is no floor plan either so effectively all APs are in the same place as far as XIQ is concerned so heat maps will not work I presume in this case.
Thanks,
Rob
ā08-29-2024 04:48 AM
You configure the APs TXPower and channel according to the project, usually. If using Auto RF, configure a custom 3dB power range for each radio (2.4 -6dB usually lower than 5 and 6 GHz).
Maps are essential in managing and troubleshooting a WLAN.
ā08-30-2024 02:16 AM
Thanks Jan for your post. Adding APs on floor plans certainly helps. Good to get real time advice so thank you.
ā08-30-2024 03:23 AM
My recommendation is to manually choose channel and power level if possible as a rule of thumb. Is 2.4 GHz band your primary concern or 5 GHz?
ā08-30-2024 05:32 AM
I also prefer manual channel plans, up to a certaing total numer of APs. When you deal with the hundred/thousand numbers, manual channels are hard to manage.
