09-26-2021 10:41 AM
I have a issue with Log in Problem with my AP7632i
What is the username Password?
And i also tried "admin” Pass word is blank and also password abc123
Solved! Go to Solution.
09-27-2021 12:14 PM
Resetting the AP using the reset / FactoryDefault credentials only work when done via the console port. They will not work when SSHing into the AP.
Please console into the AP using speed (baud rate) 115200 and use above credentials to reset.
As for the browser part, since Adobe Flash has been discontinued, you’ll need to download the WiNG-Man App and use said app to access the AP via GUI.
https://extremeportal.force.com/ExtrArticleDetail?an=000085391
Thank you
09-26-2021 10:33 PM
The default login is:
admin / admin123
If the password has been changed and you do not know it, you will have to reset the AP back to default. You can do this by logging into the AP with the credentials:
