Auto shutdown - How does it work?
Tuan_Nguyen1
Hi everyone
Function auto shutdown how does it work? I disconnect the network but the SSID was not turned off.
1 ACCEPTED SOLUTION
RobertZ
The Auto Shutdown feature causes the WLAN to shut down when certain criteria are met. It also allows administrators to set the operating days and hours of certain WLANs for security or bandwidth purposes.
18 REPLIES 18
ckelly
SmartRF is simply the mechanism that allows for automatic power and channel management of the radios.
It does not have any ability to disable a WLAN on a radio. It should not have the ability to affect the problem being discussed here.
Tuan_Nguyen1
Hi everybody
Is smart-rf related to this problem. I'm turned on Smart-rf
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-disable-the-Smart-rf-2-0-Select-Shu...
ckelly
Still recommending to contact GTAC to report this behavior.
JohnDalosy
It seems that the radio still transmit the WLAN but the client isn't able to connect to this WLAN.
