Auto shutdown - How does it work?
Tuan_Nguyen1
Hi everyone
Function auto shutdown how does it work? I disconnect the network but the SSID was not turned off.
1 ACCEPTED SOLUTION
RobertZ
The Auto Shutdown feature causes the WLAN to shut down when certain criteria are met. It also allows administrators to set the operating days and hours of certain WLANs for security or bandwidth purposes.
18 REPLIES 18
ckelly
Tuan, please contact GTAC and reference this this Hub discussion.
Tuan_Nguyen1
Hi @fserve
Have you resolve this prolem?Nops šŸ˜ž
2 AM yesterday i had to unplug power my AP because I lost LAN to AP but signal is still very strong and there is no internet. This is terrible
fserve
Hi @fserve
Nops ļ˜ž
Tuan_Nguyen1
Hi @fserve
fserve
I've made some tests and, with the LAN unplugged the SSID still being broadcasted very strong from this AP that is near me, but i can connect without any problem to the other AP that far away.
