How to debug "Error: unhandled value 0 for OFDM l_sig_rate"
Valter_Veiga
New Contributor III
Hello,
How can I debug the following message ?
Oct 30 02:16:29 2019: %KERN-6-INFO: [401607.670569] athko_fill_wips_rxinfo: Error: unhandled value 0 for OFDM l_sig_rate.
1 ACCEPTED SOLUTION
ckelly
Valter, I can’t say 100% based on the message itself:
At this point, now that you’ve upgraded to 5.9.7 and are continuing to see the message, I would recommend reaching out to GTAC.
If you wanted to explore the possibility that this is a ‘opportunistic’ rate selection standard problem, try could try changing from opportunistic to standard and see if the messages continue.
7 REPLIES 7
ckelly
I can’t find anything that specifically matches this error message in the subsequent release notes, but there are a 2-3 SPRs that are marked as fixed in 5.9.6 that sound like they MIGHT be related to this message.  For now, at least as a test, I’d try upgrading to 5.9.6 and see if the message re-appears.  If it does, I’d certainly recommend opening up a case with GTAC.
Valter_Veiga
New Contributor III
Hi Chris,
AP7632 version 5.9.4.1-004R
Copyright (c) 2004-2019 Extreme Networks, Inc. All rights reserved.
Booted from primary
ckelly
Valter,
What version of WiNG is running on this AP?
