‎06-12-2024 12:30 PM
Hello guys, I have a question. Is it possible to add an additional AP (no root) on the client's side via cable in a Mesh network? The situation looks like this: WWW <-> AP6522 <-> Mesh -> AP7522 <-> Cable -<> AP6532. Generally, the Mesh connection works, but connecting AP6532 introduces anomalies ( lost ocnnection to www, cannot connect to WLAN). Is there any setting that needs attention? We are using Wing 5.8.4.
‎08-23-2024 12:41 AM - edited ‎08-23-2024 04:34 AM
Hello guys, the clean up with VLAN an cleaning mac-address-table solve problem. Everything works fine at the moment.
Connection without switch works fine. I have 5.8.6.5-002R
‎06-13-2024 06:06 AM - edited ‎06-13-2024 06:08 AM
Hi Kamelek,
This should be possible.
It would be highly recommended to upgrade to min 5.8.6.5 ideally 5.8.6.9
If you are still seeing issues we would need a sample config from the AP7522 and AP6532
‎06-13-2024 05:47 AM
Hello @kamelek,
Have you tried AP6522 <-> Mesh <-> AP7522 <-> Cable through ge1 <-> switch <-> Cable <-> AP6532 ge1?
Is this the setup you have?
Are wireless client able to connect to the AP7522 without issues?
Is this happening on the 2.4 or 5GHz radio?
So wireless clients are able to connect to the AP6532 but are having connection issues right?
BR,
