Newly Added SSID Not Showing Up On System
‎09-12-2019 07:20 PM
We are using the RFS-4010 Controller running firmware version 5.9.2.3-003R. We have created a new SSID (Tappan) and it is not showing up for clients.
I have configured all of the settings in the Basic section:
and setup the security settings for it:
I also checked on the virtual interface for the controller and I have the new network setup for VLAN 200 and it is configured on the controller:
What would prevent the new SSID from being visible to clients? Thanks in advance for your assistance.
4 REPLIES 4
‎09-12-2019 10:56 PM
You guys are AWESOME!! Thanks for all of your help!
‎09-12-2019 07:59 PM
this might help:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-do-I-Create-a-WLAN-on-my-WM-Controller
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-aren-t-the-APs-broadcasting-the-WLAN-SSID
1 - Create WLAN (above instructions)
2 - Map to vlan (VLANs have to be created first)
3 - Map to radio
4 - Make sure your country code is set in the RF-Domain
3 - Map to radio
Some ideas can be found here (yours is the 3rd point):
Here are instructions on mapping the WLAN to the radios:
Thank you,
Christoph
Thank you,
Christoph
Christoph S.
‎09-12-2019 07:24 PM
What you've done is just CREATE the WLAN and define its many operational characteristics.
You now need to specify which radios should use that WLAN Profile. This is a recurring theme in WiNG. You create profiles and policies....and then you have to specify that a device should actually use them.
Go into the AP Profile, interfaces, radios, mapping tab, and move the WLAN Profile over so that it's "mapped" to the radio.
