07-24-2024 01:18 PM
Hello,
we recently purchased the POE++ Switch 5420M-24-4YE. Our application requires Multicast. We tried to set it up but it doesn't work. Can you help us walk through the steps.
This is what we have done so far:
Enabled IGMP Snooping
Enabled PIM
Thank you.
07-31-2024 06:35 AM - edited 08-01-2024 03:28 AM
Your willingness to help out with such a thorough solution means a lot. NCEdCloud Thank you for your effort and insight!
07-29-2024 02:15 AM
Which OS are you using? Fabric Engine or Switch Engine? In Fabric enable multicast for SPBM.
In Switch Engine (EXOS):
Remember that only one querier exists per LAN segment and it is the lowest IP in VLAN.
What are the results of show igmp vlan <your service VLAN> ? Do you see there your application?
PIM (SM/DM) is required only when you are going to provide multicast service for another broadcast domain than the IGMP source. If it is the case, please check the TTL (Time-To-Live) set by your application because sometimes applications (VLC is the example I know) sets this attribute by default to "1" which doesn't allow any multicast routing at all.
07-25-2024 12:47 AM
divram,
The information provided is too scarce to be able to help you.
Important information is:
You can start here: https://extreme-networks.my.site.com/ExtrSearch#q=multicast&t=Knowledge&sort=relevancy&f:@sfdatacate...
Mig
