General Network Management
Questions and discussions about general network management practices
XMC MAP shows link partially down
Have MLT with two ports (1/1 and 1/2) between two VSP 8404 switches both discovered by XMC 8.5.2.6but link shows Partially Down and not recognising that port 1/1 has been fixed. Port 1/1 was down for sometime and has recently come up after a faulty f...
RobertD1 by • Contributor III
  • 919 Views
  • 0 replies
ERS 4850 SNMP
Is it possible to use SNMP (v2c) on the ERS 4850 to configure a RADIUS server? If not that, is it possible to set the login to use local instead of RADIUS, also via SNMP? We have a few switches that someone configured with an incorrect IP and we’re u...
bfaltys by • Contributor II
  • 2729 Views
  • 2 replies
RMK for X460G2 (4 post)
I’m trying to find a 4 post RMK for the X460G2 model of switch.  We have a 2 post RMK right now, but the switches are sagging in the back.We have a 4 post RMK for X450G2, but that kit won’t work for the X460G2, as they X460G2 doesn’t have the nobs on...
B_ by • New Contributor II
  • 2869 Views
  • 3 replies
