â06-18-2020 09:48 AM
I have the problem that unauthenticated clients are not automatically redirected to the internal captive portal page of the XCA, but they can access the page when they type in the IP address of the XCA.
I already tried this with many different clients.
What can be the cause of this problem?
In the Identify world there were several options to trigger the automatic redirection, but on the XCA i have no clue what is required to let this work.
The Setup is:
VE6120 Small
Version 04.76.04.0005
AP310i Access-Points
Solved! Go to Solution.
â06-19-2020 07:00 AM
Client ip: 192.168.201.27
DNS : 192.168.100.115
XCA : 192.168.100.131
â06-19-2020 06:46 AM
Hey Ronald,
yeah i am just thinking of setting the XCA to factory defaults right now. The default VLAN is configured for bridge@AP. Its the default topology âbridge @ AP untaggedâ.
Thanks for the link.
â06-19-2020 06:43 AM
Hi Christoph,
The screenshot with the âvlan-201â is from Santosh.
I am using B@AP untagged as default VLAN, which is in my case the local breakout VLAN, where the XCA is the DHCP-Server and holds the Captive Portal. So the XCA is in the same subnet as the Clients.
I set 8.8.8.8 as DNS server.
â06-18-2020 08:30 PM
I just installed a fresh XCA with latest code and itâs working for me.
-Ron
I know itâs for Identify but could be that gives you an idea how it works in general - itâs the same principle for XCA.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-a-Guest-Portal-Service/
â06-18-2020 04:23 PM
In the Default Auth Role vlan-201-role whatâs configured for DNS access?
â06-18-2020 01:56 PM
A rule issue seems to be the most plausible explaination for this behavior as well.
