AP aware - how is it supposed to work?
Flavio
New Contributor III
Hi all.
I’m wondering how “AP aware” feature is supposed to work. Is anybody using it and could share how it should be configured and intended to be used?
Thanks,
Flavio.
12 REPLIES 12
Ronald_Dvorak
Honored Contributor
Hi Flavio,
you use the feature if you do authentication (e.g. 802.1X) on the switch ports.
Because most of the time you would use a bridge@AP topology for WLAN APs = clients break out directly at the AP port that would mean that the client needs to be authenticated on the WLAN AND on the switch port.
As a double authentication doesn’t make much sense you’d use AP aware to “disable” authentication on the switch port that has a AP connected to it.
Hope that makes sense.
-Ron
Flavio
New Contributor III
Hi Ronald.
That I already found - but that’s not explaining how to apply it and in what situation it is really useful. I’d like to have some examples…
Thanks,
Flavio.
Ronald_Dvorak
Honored Contributor
