XMC Syslog alarm wildcard
I'm setting up some custom alarms in xmc based of syslog messages and was wondering if there is a wildcard matching option in the Information Phase. Will \d or * work? Such as matching "something [number] something"
Hello, I deleted a workflow by mistake, and would like to know if there was a way to recover it. Thanks a lot in advance.
Hi @all, Since two months we are using Netsight NAC. Before was our NAC managed by macmon (www.macmon.eu). macmon procedere: Macmon scan every minute the switch for a change. In this case macmon changed the vlan into the right one (authorized devic...
Hi all, We have removed some switches from the Devices Tab on XMC, yet under Archives some switches are reported as File not found/Missing. I cant understand why it would report the backup failing if the switch no longer exists and not anywhere in ...
I am currently migrating from Netsight 7 to XMCv8. I have entered the new XMCv8 SNMPv3 information in to my edge switches (X460-G2s) and the switches are discoverable by the new XMCv8. In testing I used "add Trap Receiver" check box under the action...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
