Could I see syslog messages from OneView?
Hello, everybody, now I can find syslog messages only in Legacy Java "Console" application. Could it be found in Oneview? Thanks
Hi All. I’m in a process of fisrt configuration of netsight. I wish to add XOS switch (X440-g2) to netsight by using script snmpassist. Unfortunately there is no connection over SNMP. There is connection through CLI from netsight to the switch. I...
I am trying to install the new version of EMC version 8.0.4 at the recommendation of the manufacturer, but it has not been possible because of any of the ways I try with OVA, ISO or other does not work the installation and gives the error attached in...
Hello, our customer has 18 tenants in a building which share a common it infrastructure. Each tenant should be able to access the common resource telephone system and internet. The tenant networks should be separated. What I did: a vlan for each tena...
Hi all, I apologize in advance if I missed the answer. We have two domains in the same forest, parent domain X.Y and child domain Z.X.Y. We would like to setup AD/LDAP authentication to EMC so that users from both domains can access to EMC portal....
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
