Bulk add MAC Addresses
Is there a way to import a list of MAC addresses into the NAC? Example: A list of printer MAC addresses that need to be authenticated and placed in a specific VLAN.
Just tried to make a port change through EMC on an Enterasys C5 switch*, after doing the enforce, lost VLAN port configuration. Would this be because the edit should have been done through the java Netsight client? Love to get some advice. Th...
I am trying to add a new user to EMC (other than root) in version 8. I can add the user and add them to the authorization group, but cannot add/set a password. I am set to OS authentication. I'm positive I'm overlooking something stupid
How do I create and send via email for the used ports capacity report from Extreme Management Centre.
I need to configure my switches and netsight to give an alarm every time a port state change. It'd be amazing if I can configure different alarms with different names for different ports! for example: -port 1 - alarm1 -port 2 - alarm 2 and so... No...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
