Netsight block in downloading update definition from server...
Hello Team, I have netsight 8.0.2.42, when i choose Network=>Legacy=>Console, the execution of netsight bloque in Downloading update Definition From Server... Lien vers mon image
Hi All, A while back I had an issue raised with regards to a certain flexview not being available within EMC. I was provided in the initial instance with the .tpl file to manually enter it into the specific directory but everytime i upgrade EMC i h...
Hello, Yesterday I upgraded Netsight to version 8.0.2 from 7.1.2 Since then the java gui is not working. The App is loading and asks for username + pw, I sure provide correct values but the app cannot connect to netsight server: telnet from my cl...
Hi, I've got in my demokit environment a strange problem. My EMC for some time has worked well as syslog server, but not despite the fact that I see the syslog messages correctly received in the /var/log/syslog file in the Oneview page or in console...
When looking at the network map in Oneview - switches don't show the link when using the management port - is there a way to have oneview display those links?
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
