Question about vlans
I'm creating 2 vlans 1 for workstations and another for ip cameras. If someone's workstation is not on that vlan w they be able to view the cameras from there workstation?
Hello, I've setup an EMC lab for testing NMS advanced features, specifically the maps wireless coverage. I've added the controller to EMC, enabled location services under the radar configuration on the controller and on the AP's themselves. I crea...
just purchased extreme network 440 and a new router. Its my understanding i don't need a router that the switch can do dhcp as well? if this is the case how would i set the static from my isp on a specific port and be able to utilize the rest of the ...
Working with an End Customer on a NAC deployment with iBoss integration. Within the OFConnect configuration for iBoss, under 'Specific Configuration' there is the field 'Ignore usernames that contain'. We have used that effectively for one aspect...
we have Netsight and NAC 7.0.3.11, we are planning to use agent based and agent less assessment simultaneously. in our testing, agent based is working perfectly but in agent based we have issue in "Health result" where the information is incomplete. ...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
