Netsight Console - new (custom) tab for EWC Station Events only
M_Nees
Contributor III
for better WLAN troubleshooting i forward all my EWC StationEvents to Netsight. i forward it via syslog - local3 facility into a separate log-file - which resides on netsight server - /var/log/StationEvents.log.
EWC is filling these with station events - all working fine!
(tail -f /var/log/StationEvents.log is filling up)
On Netsight Console i created a new tab - Wireless-StationEvents. How can i get Console that the content of the above file will shown here ?
i am not able to define a log source which is Type = Server - means a log-file which rely on netsight server.
(log-file target was /var/log/StationEvents.log - but Console change this to local c:\....)
The other (default) tabs show me that is should be possible, but how ???
14 REPLIES 14
Hello Matthias,
I have run into this problem myself and am currently in discussions with engineering regarding this issue.
Thanks
-Ryan
M_Nees
Contributor III
Hi Drew,
any news to my demand ?
Regards
Drew_C
Valued Contributor III
This one is being passed around internally. Hopefully we can get you an answer soon, Matthias.
Ronald_Dvorak
Honored Contributor
Just tell that it's for a NFL stadium and you host the next super bowl - I'm pretty sure you get help ļ™‚
StephanH
Hello Matthias,
the problem is the type of the Log Manager. I think you need a Log Manager with type "server".
You can try to change the path of an available Log Manager to your new directory.
84ef59ef02194b5ea082dde72d2f96c6_RackMultipart20170208-89697-130x5qh-LogManager_inline.jpg
BUT you can only create new Log Managers with type "local" in this config window šŸ˜ž.
Sadly I don't know if there is a way to create Log Manager with typ "Server".
Regards
Stephan
Regards Stephan
