Syslog setup for X440 switches on Netsight.
Joseph_Chacko
I an trying to setup the syslog option in NetSight(6.2.0.211). Whenever I right click the device and select the Syslog Receiver configuration, it says, the selected device is not supported. I have enabled the syslog optin in the switch. Please help
5 REPLIES 5
Ronald_Dvorak
Honored Contributor
Netsight only makes it easier to configure the syslog settings on supported devicese.
As you've mentioned the X440 isn't supported.
But if you configure it on the device via CLI you should be set and receive the syslog messages.
I've followed the steps in the below article and now I get the messages from my X430 in the Netsight Syslog tab.
So give it a try....
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-a-syslog-server/
-Ron
