client roaming to prefered radio caused radius authentication event which failed
M_Nees
Contributor III
Currently i have a very strange problem.
We use EAP-TLS 802.1x Authentication for a internal SSID for notebooks. EWC is installed at the headquarter. 2x AP 3705 installed on the affected branch - we use V9.21.07. NAC Gateway 6.2.0.x installed also in the headquarter and is the RADIUS proxy to the NPS on the Windows AD 2008 Server. This working well over the last years.
Now we change the WAN connection of this branch from MPLS to VPN with IPSec. After this change a lot of internal WLAN clients which connected before without problems are rejected from the NAC Gateway. All other branches working well. At wired switches we use only MAC Auth which is also not affected.
Error:
802.1x (identify) - Authentication became stale
After some troubleshooting i realized that if the client roam within the AP to its prefered radio for that roaming event a radius request is triggered. The the first request (to the first radio) is always possitive (accepted) and then the AP internal switch to the prefered radio triggers a RADIUS request which is always rejected - with the above error message.
For a temporary solution i disable radio 1! And then all client can login without problems!
This is very strange.
First question:
Why do an switch from radio 2 to radio 1 trigger a radius event. Can i disable this new login request in the AP / EWC config?
Second Question:
If this request is needed why does it become stale and will be rejected?
Thanks for any advices.
Regards
22 REPLIES 22
Hi Gareth,
Secure Tunnel is disabled completely. NAT is not involved!
Customers network is divided in Subnets in 10.x.x.x IP Range. HQ and Branch are connected via IP-Sec Tunnel without any kind of NAT.
Regards
Frank_Veen
New Contributor II
Did you try enabling fast roaming?
Regards
Ronald_Dvorak
Honored Contributor
In my opinon it make sense to see a 2nd 802.1X authentication if radio preference is enabled as the client doesn't roam between the radios - it's a new connection.
I think as a workaround you'd also disable radio preference and enable radio#1 again - I'm pretty sure that will work.
Then enable it only on one AP so you'd troubleshoot the issue with the GTAC.
Hi Ronald,
we configure prefered radio on the client devices - windows driver settings.
I see this is possible via AP "Load groups", but this is not configured.
Regards
Zdeněk_Pala
Reagrding the reauthentication, I believe it is part of standard that authentication-association to new BSSID means new encryption keys generation. If your client does support OKC then you can enable it.
Regards Zdeněk Pala
