Mesh with two AP with additional cable AP
kamelek
Hello guys, I have a question. Is it possible to add an additional AP (no root) on the client's side via cable in a Mesh network? The situation looks like this: WWW <-> AP6522 <-> Mesh -> AP7522 <-> Cable -<> AP6532. Generally, the Mesh connection works, but connecting AP6532 introduces anomalies ( lost ocnnection to www, cannot connect to WLAN). Is there any setting that needs attention? We are using Wing 5.8.4.
3 REPLIES 3
kamelek
Hello guys, the clean up with VLAN an cleaning mac-address-table solve problem. Everything works fine at the moment.
Connection without switch works fine. I have 5.8.6.5-002R
Daren_E
Hi Kamelek,
This should be possible.
It would be highly recommended to upgrade to min 5.8.6.5 ideally 5.8.6.9
If you are still seeing issues we would need a sample config from the AP7522 and AP6532
Christoph_S
Hello @kamelek,
Have you tried AP6522 <-> Mesh <-> AP7522 <-> Cable through ge1 <-> switch <-> Cable <-> AP6532 ge1?
Is this the setup you have?
Are wireless client able to connect to the AP7522 without issues?
Is this happening on the 2.4 or 5GHz radio?
So wireless clients are able to connect to the AP6532 but are having connection issues right?
BR,
Christoph S.
