EMC Event tab
The Event tab is completely empty and I hoping that it would have change log type of events. Would the Event tab be the right place? If so, how do you get the events to show up?
Hello, I am using Netsight 6.3.0.168 and I am trying to find a way to create some trend by using MIBs. For example I need to monitor the CPU utilization of all Switches and show it in a monthly trend. The same also for some port bandwidth or utiliz...
Hi Hub Community,I’m having issues to set up the Alarms for my Wireless APs, specifically the AP out/in service alarms.So, I’m sharing the screenshots of the config of the alarm on XMC. Both of these alarms are applied to my HA EWC pair (C5215).When...
Hi All,Is it possible for me to get the log file off the NAC appliance in regards to the OS detection failure log?I would like to sift through the unrecognised DHCP fingerprints so I can add them to the detection type. I can only get the log to show ...
I have a column in a flexview that I’d like to display a color button depending on the value. I was able to make that working in the console but in Oneview it does display the column, but no color button or the value, only a dash string. I was lookin...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
