Use HTTPS for connection to WebView Extreme Switching on EMC
Hi, i would like to configure EMC to use HTTPS when i want to open the WEB Interface of my switch. Do you know where i can configure this option, if possible? Thanks! Bye
Just upgraded to XMC 8.2.4.42 and was hoping it would fix the issue with my syslog events now showing in the Events window. If I go to the Syslogs folder on the server I see them there but for some reason they are not getting replicated to the Event ...
Hi, i'm actually designing user right to device in xmc 8.2. For the example, the user "DIT" should be able to have full right on certain devices and only read-only right to certain other device. I created a local user "DIT" in a specific user-grou...
Good morning people, All right? In my company we have a network with 3 manageable switches of Enterasys, all model 3G124-48 and 2 VLANS, all interconnected with each other. It turns out that my company is expandindo and with that will increase the ...
hello, how can i install the Extreme connect API? is there any documentation? thank you in advance.
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
