Analytics Flow detail sometimes no response time
why there is no response time in some flow details?
Hi all, I have the question regarding application analytics. We would like to have on the NOC screen dashboard that shows network and application response time for some custom applications. Most suitable view for the cust...
Hi, we are using NAC to assign policies and a location-dependent VLAN-ID for untagged VLANs on our User ports (Summit x450-G2- and Enterasys G3-Switches). So we have at Control / Access Control / Configuration / Policy Mappings a policy mapping table...
We have a LAB running with a basic dot1x setup for NAC and also a very basic AD setup. I created a few users and integrated the LDAP connection with nac successfully. This all works just fine on MAC based solutions. I can also successfully connect on...
Is there a feature in Extreme Management Center 8.1.0.52 where you can obtain VLAN detail information, such as what EAPs ring it is protected by. In Ridgeline 4.0 you would select a VLAN from the VLAN Tab and it would provide all the detail informat...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
